Hallo, ik krijg sinds kort tijdens bijna elke rit met mij Polo AW een lane assist foutmelding samen met het EPC lampje dat aangaat. Soms gaat ook het motor lampje branden.
Ik heb de computer uitgelezen (zie onderstaand) maar ik weet niet precies waar ik moet beginnen.
Iemand een idee wat er aan de hand kan zijn?
Car Scanner ELM OBD2
Version: 2.1.25/2.1.25/iOS
DTC report
Connection profile: Volkswagen MQB, PQ26: TSI/TFSI EA211 1.0L/1.2L/1.4L/1.5LDate: 6/25/2026 7:13:20 PM
VIN:
OBD-IIOBD-II
DTCs: 1
P2D10 [0x2D10]
Status: Confirmed
19. CAN Gateway
No DTC found.
09. Onboard supply control unit
No DTC found.
02. Transmission control unit
No DTC found.
03. ABS control unit03. ABS control unit
DTCs: 1
01209 [0x0004B9] Archive (inactive)
U112300: Databus error value received
Scl_ACC_Anhalteweg_Error
Status bits: 1
Priority: 3
Frequency: 11
Unlearning index: 227
Odometer: 40017 km
Date, time: 2026.06.21 10:58:12
Status: Confirmed
01. Engine control unit01. Engine control unit
DTCs: 1
38150 [0x009506] Archive (inactive)
P16D400: Torque limit, Because of pre-ignition
P2D1000: Engine Pre-Ignition Above Threshold - Forced Limited Power
Status bits: 1
Priority: 2
Frequency: 254
Unlearning index: 255
Odometer: 38453 km
Date, time: 2026.05.20 07:46:25
Engine RPM: 3004 rpm
Calculated engine load value: 57.65 %
Vehicle speed: 133 km/h
Engine coolant temperature: 90 ℃
Intake air temperature: 40 ℃
Barometric pressure: 101 kPa
Klemme 30 voltage: 14
Paramteric values: 20 96 28 F4 04 93 F4 0E 97 44 CD 03 2C 58 52 0E 5F 44 60 0D B4 44 DD 03 65 10 9C 2E EF 20 1A 00 03 20 1E 01 A0 F4 11 DA 3D 9F 04 59 2A 07 38 07 44 D0 15 D9 02 8D 01 E7 20 2F 0E 5D
Status: Confirmed, Test failed since last DTC clear, Test not completed during this operation cycle
04. Power steering
No DTC found.
08. Heater and climate
No DTC found.
10. Parking Assistant 2
No DTC found.
13. Active cruise control13. Active cruise control
DTCs: 3
02111 [0x00083F] Archive (inactive)
FAULT_ESP_CONS_ACC
Status bits: 1
Priority: 4
Frequency: 35
Odometer: 38453 km
Date, time: 2026.05.20 07:46:26
Paramteric values: 02 85 94 02 8D 56 10 11 26 97 10 12 F8 C0 10 2E 07
Status: Confirmed
00928 [0x0003A0] Archive (inactive)
U112200: Databus implausible message
FAULT_STOPPING_DISTANCE_CONTROL_NOT_AVAILABLE
Status bits: 1
Priority: 6
Frequency: 35
Odometer: 38453 km
Date, time: 2026.05.20 07:46:27
Paramteric values: 02 85 94 02 8D 56 10 11 26 77 10 12 FA 80 10 2E 07
Status: Confirmed
02068 [0x000814] Archive (inactive)
FAULT_TSK_IRREV_FAIL
Status bits: 1
Priority: 6
Frequency: 35
Odometer: 38453 km
Paramteric values: 02 85 94 02 8D 56 10 11 27BC 10 12 FA C0 10 2E 02
Status: Confirmed
15. SRS
No DTC found.
17. Dashboard17. Dashboard
DTCs: 1
16777018 [0xFFFF3A] Archive (inactive)
U111000: Function restriction due to communication interruption
BAP_Audio_0x31 keine Kommunikation
Status bits: 1
Priority: 6
Frequency: 1
Unlearning index: 36
Odometer: 40248 km
Date, time: 2026.06.24 12:07:14
Status: Confirmed
44. Power steering
No DTC found.
55. Headlights corrector
No DTC found.
5F. Electronic Information System 1
No DTC found.
75. Emergency Call and Communication Module
No DTC found.
76. Parking assistant
No DTC found.
A5. Front Assistant A5 (UDS)
No DTC found.
DTC report
VIN:
OBD-IIOBD-II
DTCs: 1
P2D10 [0x2D10]
Status: Confirmed
19. CAN Gateway
No DTC found.
No DTC found.
No DTC found.
DTCs: 1
Status bits: 1
Priority: 3
Frequency: 11
Odometer: 40017 km
Status: Confirmed
DTCs: 1
Status bits: 1
Priority: 2
Frequency: 254
Odometer: 38453 km
04. Power steering
No DTC found.
No DTC found.
No DTC found.
DTCs: 3
FAULT_ESP_CONS_ACC
Status bits: 1
Priority: 4
Frequency: 35
Odometer: 38453 km
Status: Confirmed
Status bits: 1
Priority: 6
Frequency: 35
Odometer: 38453 km
Status: Confirmed
Status bits: 1
Priority: 6
Frequency: 35
Odometer: 38453 km
Status: Confirmed
15. SRS
No DTC found.
DTCs: 1
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 40248 km
Status: Confirmed
44. Power steering
No DTC found.
No DTC found.
No DTC found.
No DTC found.
No DTC found.
No DTC found.
6C
