Weet iemand of dit filter het vermogen van de polo vergroot?
http://cgi.ebay.nl/K-N-SPORTLUFTFILTER- ... 230ad2efbe
The second reason is to keep the throttle body from freezing. Yep, that's right. I said freezing. As in ice forming inside the throttle body.
Anyone who lives where it gets cold in the winter has heard of "wind chill". It'll be 0° with a wind chill of -10°. As the air moves through the throttle body, the same wind chill affects the inside if the throttle body(dat is dus het gasklep huis). Under certain conditions, such as high humidity, condensation will form inside the throttle body and the moving air will freeze it. This ice will keep building up until it chokes off the air supply and the engine dies.
By running hot coolant through passages in the throttle body, it keeps the throttle body warm and prevents this ice from building up.
Some early fuel injected engines did not have heated throttle bodies and ice formation was such a problem that heated throttle bodies were retro fitted at the dealerships.
