Saturday,26,March,2011,21:05:06:46862
VCDS Version: Release 10.6.0
Data version: 20100630
Chassis Type: 6R0
Scan: 01 03 08 09 10 15 17 19 25 2E 37 44 56 61 77
VIN: WVWZZZ6RZAY213588
01-Engine -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
2E-Media Player 3 -- Status: Malfunction 0010
37-Navigation -- Status: Not registered 0011
56-Radio -- Status: Malfunction 1010
61-Battery Regul. -- Status: OK 0000
77-Telephone -- Status: Not registered 0001
Address 01: Engine (J623-CAYB) Labels: None
Part No SW: 03L 906 023 EP HW: 03L 906 023 D
Component: 1,6l R4 CR td H13 6006
Revision: -------- Serial number:
Coding: 00114036002401080000
Shop #: WSC 124697 483 00190
ASAM Dataset: EV_ECM16TDI02103L906023EP 001003
ROD: EV_ECM16TDI02103L906023EP.rod
VCID: 78F4EABE34895DDC
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 6R0 907 379 AF HW: 6R0 907 379 AF
Component: ESP8.2i front H05 0005
Revision: --------
Coding: 210228E3416E00B5842A14EA82D900521300
Shop #: WSC 02069 000 00000
VCID: 82000856E255870C
1 Fault Found
00283 - ABS Wheel Speed Sensor; Front Left (G47)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 0
Fault Frequency: 5
Reset counter: 29
Mileage: 21407 km
Time Indication: 0
Date: 2011.14.18
Time: 15:46:15
Freeze Frame:
Hex Value: 0x0007
Hex Value: 0x0000
Hex Value: 0x30B1
Hex Value: 0x067C
Hex Value: 0x007F
Hex Value: 0x7F7F
Hex Value: 0x7F00
Address 08: Auto HVAC Labels: None
Part No SW: 6R0 907 044 B HW: 6R0 907 044 B
Component: Climatronic H08 0305
VCID: 326018969275778C
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 09: Cent. Elect. (J519) Labels: Redir Fail!
Part No SW: 6R0 937 088 HW: 6R0 937 088
Component: BCM PQ25 Re4 H46 0304
Revision: BU046001 Serial number: 0104 053100112
Coding: 3CB82BBF08A10000013001303C2B0ED08F80610F7E060041200000000000
VCID: FBFE75B285BFF6C4
Part No: 1K0 955 559 AH
Component: RLS 200210 05 54 0403
Coding: 0005F3
Part No SW: 6R0 959 801 R HW: 6R0 959 801 R
Component: J386__TSG_FT 006 0902
Coding: 48BC30
Part No SW: 6R0 959 802 T HW: 6R0 959 802 T
Component: J387__TSG_BT 006 0902
Coding: 48BC30
Part No SW: 6R0 959 811 F HW: 6R0 959 811 F
Component: J388__TSG_HL 006 0902
Coding: 48BC32
Part No SW: 6R0 959 812 F HW: 6R0 959 812 F
Component: J389__TSG_HR 006 0902
Coding: 48BC32
3 Faults Found
00910 - Indicator Lamp for Emergency Flashers (K6)
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 3
Fault Frequency: 1
Reset counter: 23
Mileage: 22604 km
Time Indication: 0
Date: 2012.14.03
Time: 19:41:31
03301 - Response Closing Status of Drivers Door
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 33
Mileage: 21595 km
Time Indication: 0
Date: 2011.14.21
Time: 12:50:44
03224 - Play Protection Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 3
Reset counter: 33
Mileage: 21594 km
Time Indication: 0
Date: 2011.14.21
Time: 10:40:44
Address 10: Park/Steer Assist (J446) Labels: 6R0-919-475.clb
Part No SW: 6R0 919 475 HW: 6R0 919 475
Component: PARKHILFE 4K H07 0008
Revision: -------- Serial number: 71391003930756
Coding: 100001
ASAM Dataset: EV_VW250ParkiAssis2 S01006
ROD: EV_VW250ParkiAssis2.rod
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 6R0 959 655 C HW: 6R0 959 655 C
Component: VW10Airbag008 H09 0018
Revision: -------- Serial number: 003DW00D7U7J
Coding: 003038
ROD: EV_AirbaVW10BPAVW250_VW25.rod
VCID: 4280485622D5C70C
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6R0 920 861 C HW: 6R0 920 861 C
Component: KOMBI H03 0207
Serial number: 00000000000000
Coding: 140A00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
VCID: 356A238A631B60B4
Address 19: CAN Gateway Labels: 6R0-907-530.clb
Part No SW: 6R0 907 530 B HW: 1K0 907 951
Component: J533 Gateway H28 0020
Revision: H28 Serial number: 170210F2000505
Coding: 7D231D00080000000002
2 Faults Found
01304 - Radio
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 7
Reset counter: 45
Mileage: 21032 km
Time Indication: 0
Date: 2011.14.14
Time: 10:34:06
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 254
Mileage: 18244 km
Time Indication: 0
Date: 2009.14.21
Time: 11:18:33
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H03 0207
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03006
ROD: EV_Immo_UDS_VDD_RM09_VW25.rod
VCID: EAD040F6FA257F4C
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
Component: SG EXT.PLAYER H13 0090
Revision: A1001003 Serial number: 7667794666
Coding: 010000
VCID: 2648F4C6AEBD1B2C
1 Fault Found
01304 - Radio
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 5
Reset counter: 45
Mileage: 21439 km
Time Indication: 0
Date: 2011.14.19
Time: 12:07:54
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 C HW: 1T0 035 680 C
Component: RNS-MID H06 2680
Revision: AB001001 Serial number: VWZ6Z7K7077011
Coding: 04010402040000A000
Shop #: WSC 05314 000 00000
ASAM Dataset: ------------------------- ------
VCID: 2E580CE6864D536C
1 Fault Found
01523 - Microphone for Telephone (R38)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 89
Reset counter: 26
Mileage: 21409 km
Time Indication: 0
Date: 2011.14.18
Time: 16:10:37
Address 44: Steering Assist Labels: 6Q0-423-156.lbl
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11230
Shop #: WSC 00788
VCID: 2F6611E281475A64
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
1 Fault Found
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 89
Reset counter: 26
Mileage: 21409 km
Time Indication: 0
Date: 2011.14.18
Time: 16:10:37
Address 61: Battery Regul. (J840) Labels: None
Part No SW: 6R0 907 534 HW: 1K0 907 951
Component: Batt.regelung H28 0020
Coding: 030B1A5A
VCID: F4EC5E8EA8E1B9BC
Component: J367-BDM H07 0125
Address 77: Telephone
Cannot be reached
End ---------------------------------------------------------------------
