Help VCDS
Joey070
Ik heb een roetfilter melding en wil deze graag uitlezen d.m.v VCDS. Echter wanneer ik op auto scan klik, krijg ik geen enkele aanwijzing dat er een roetfilter lampje brandt. Doe ik iets verkeerd?
Zie bijlage.
Thursday,15,August,2019,20:43:18:39370
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.0.2
Data version: 20180927 DS296.0
www.Ross-Tech.com
VIN: xxxxxxxxxxxxxxxxx License Plate:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 08 09 10 15 17 19 25 37 44 56
VIN: WVWZZZ6RZBY037316 Mileage: 203130km-126219miles
01-Engine -- Status: OK 0000
10-Park/Steer Assist -- Status: Cannot be reached 1100
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
37-Navigation -- Status: Cannot be reached 1100
56-Radio -- Status: Malfunction 0010
Address 01: Engine (J623-CAYB) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 D HW: 03L 906 023 D
Component: R4 1.6l TDI H13 9979
Revision: --H13--- Serial number:
Coding: 00114014002400080000
Shop #: WSC 124697 483 00190
ASAM Dataset: EV_ECM16TDI02103L906023D 003014
ROD: EV_ECM16TDI02103L906023AH_003.rod
VCID: 275DC26C5E74DE72B4-8072
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AJ HW: 6R0 907 379 AF
Revision: --------
Coding: 210228E3417000B9842814E382D700421300
Shop #: WSC 02069 000 00000
VCID: 0603AFE8B5BEE77AEF-8052
1 Fault Found:
02214 - Tire Pressure Warning
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 2
Reset counter: 0
Mileage: 202918 km
Time Indication: 0
Date: 2014.01.04
Time: 19:03:46
Freeze Frame:
Hex Value: 0x4000
Hex Value: 0x8000
Hex Value: 0x3203
Hex Value: 0x2BB4
Hex Value: 0x207F
Hex Value: 0x7F7F
Hex Value: 0x770C
Address 08: Auto HVAC (J301) Labels: 6R0-820-045-9AP.clb
Part No SW: 6R0 820 045 J HW: 6R0 820 045 J
Component: Climatic 25 0660
Revision: 00 11 25
VCID: 356118249CD8BCE236-8060
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 F HW: 6R0 937 087
Component: BCM PQ25 H+4 H46 0221
Revision: BF046001 Serial number: 0345 168106051
Coding: 3AB02BBF08A10000003006003F2B1ED80080410F60040040200000000000
VCID: 408F79F0D31A094A95-8014
Subsystem 1 - Part No SW: 6R0 959 801 R HW: 6R0 959 801 R Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 006 0903
Serial number: KU0-KU011.06.1012857
Coding: 18BC30
Subsystem 2 - Part No SW: 6R0 959 802 T HW: 6R0 959 802 T Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 006 0902
Serial number: KU0-KU002.06.1011560
Coding: 08BC30
Subsystem 3 - Part No SW: 6R0 959 811 F HW: 6R0 959 811 F
Component: J388__TSG_HL 006 0902
Serial number: KU0-KU012.06.1010338
Coding: 08BC32
Subsystem 4 - Part No SW: 6R0 959 812 F HW: 6R0 959 812 F
Component: J389__TSG_HR 006 0902
Serial number: KU0-KU014.06.1015561
Coding: 08BC32
Address 10: Park/Steer Assist
Cannot be reached
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 6R0 959 655 L HW: 6R0 959 655 L
Component: VW10Airbag00G H09 0020
Revision: -------- Serial number: 003GY000J07-
Coding: 003047
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4B955EDCE25CDA1270-801E
Crash sensor for side airbag: driver side:
Serial number: 3572SRB40000BA1071C0
Crash sensor for side airbag: front passenger side:
Serial number: 3582SRB40000BA28C1DG
Crash sensor for side airbag: rear: driver side:
Serial number: 3515RRB405D6QGG0NP53
Crash sensor for side airbag: rear: passenger side:
Serial number: 3525RRB405H6SD5OEP8E
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 6R0 920 861 F HW: 6R0 920 861 F
Component: KOMBI H04 0304
Serial number: 00000000000000
Coding: 140A00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
ROD: EV_Kombi_UDS_VDD_RM09_004_VW25.rod
VCID: 387F111083CA418A2D-806C
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 0221
Coding: 002200
VCID: 70EFE930A33AD9CA25-8024
2 Faults Found:
01300 - Control Module for Navigation with CD-Rom (J401)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 219
Mileage: 203138 km
Time Indication: 0
Date: 2014.01.05
Time: 20:18:31
03075 - Parallel Parking Assistance Control Module (J791)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 219
Mileage: 203138 km
Time Indication: 0
Date: 2014.01.05
Time: 20:18:27
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Component: IMMO H04 0304
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6ADBFB588DE6231A6B-803E
Address 37: Navigation
Cannot be reached
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11260
Shop #: WSC 00788
VCID: 2F6D2A4CEA8486327C-807A
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 6RD 035 187 B HW: 6RD 035 187 B
Component: MIB2-S-R-CN 036 0317
Revision: -----001 Serial number: VWZ6Z2R7459990
Coding: 1600044004000A
Shop #: WSC 00081 790 00124
VCID: 46836FE8F13E277AAF-8012
10 Faults Found:
00881 - Connection to Speaker Rear Right
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 40
Mileage: 76363 km
Time Indication: 0
Date: 2011.09.23
Time: 14:37:56
00625 - Vehicle Speed Signal
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 118
Mileage: 0 km
Time Indication: 0
00877 - Treble Speaker Rear Right (R16)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 0
Mileage: 0 km
Time Indication: 0
00876 - Treble Speaker Rear Left (R14)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 0
Mileage: 0 km
Time Indication: 0
02873 - Control Module for Back-Up Camera (J772)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 90
Mileage: 193821 km
Time Indication: 0
Date: 2013.10.25
Time: 16:28:36
01327 - Control Module for Parking Aid (J446)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 90
Mileage: 193821 km
Time Indication: 0
Date: 2013.10.25
Time: 16:49:22
01336 - Company Data Bus for Comfort System
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 108
Mileage: 0 km
Time Indication: 0
014 - Defective - Intermittent
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 108
Mileage: 0 km
Time Indication: 0
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 108
Mileage: 0 km
Time Indication: 0
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 108
Mileage: 0 km
Time Indication: 0
End-------------------------(Elapsed Time: 02:46)--------------------------
    6 KB · Weergaven: 33
