Thursday,08,March,2018,14:35:37:54802
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 18.2.0.3 (x64)
Data version: 20180212 DS287.0
www.Ross-Tech.com
VIN: WVWZZZ6RZAY296614 License Plate:
Chassis Type: 6R-VW25 (6R0)
Scan: 01 03 08 09 10 15 17 19 25 2E 44 56 61
VIN: WVWZZZ6RZAY296614 Mileage: 212190km-131848miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
2E-Media Player 3 -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
61-Battery Regul. -- Status: OK 0000
Address 01: Engine (J000-CFWA) Labels:. 03P-906-021-CFW.clb
Part No SW: 03P 906 021 B HW: 03P 906 021 B
Component: R3 1.2l TDI H03 9978
Revision: 12004001 Serial number:
Coding: 00114014032401080000
Shop #: WSC 55345 001 1048576
ASAM Dataset: EV_ECM12TDI03103P906021B 001041
ROD: EV_ECM12TDI03103P906021AA.rod
VCID: 275709565E3B067C79-8072
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AF HW: 6R0 907 379 AF
Component: ESP8.2i front H05 0005
Revision: --------
Coding: 210224E3417600B8842B24E382D500521300
Shop #: WSC 02069 000 00000
VCID: 020178C299D903540E-8056
Address 08: Auto HVAC Labels: 6R0-907-044.clb
Part No SW: 6R0 907 044 B HW: 6R0 907 044 B
Component: Climatronic H08 0305
VCID: 3261E8026DF973D4DE-8066
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R0 937 088 HW: 6R0 937 088
Component: BCM PQ25 Re4 H46 0304
Revision: BU046001 Serial number: 0104 103100218
Coding: 22B02BBF08A10000213801307C2B0ED1CF80610F7E860041200000000000
Shop #: WSC 124697 483 00190
VCID: 7BFF0526FA33729C4D-802E
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 110510 05 54 0403
Coding: 0005F3
Subsystem 2 - Part No SW: 6R0 959 801 R HW: 6R0 959 801 R Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 006 0903
Serial number: KU0-KU004.05.1011119
Coding: 58BC30
Subsystem 3 - Part No SW: 6R0 959 802 T HW: 6R0 959 802 T Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 006 0902
Serial number: KU0-KU030.04.1017054
Coding: 48BC30
Subsystem 4 - Part No SW: 5K0 959 542 HW: 5K0 959 542
Component: E221__MFL-TAS H06 0010
Serial number: 0089498
Coding: 820000
Subsystem 5 - Part No SW: 6R0 959 811 F HW: 6R0 959 811 F
Component: J388__TSG_HL 006 0902
Serial number: KU0-KU027.04.1010961
Coding: 48BC32
Subsystem 6 - Part No SW: 6R0 959 812 F HW: 6R0 959 812 F
Component: J389__TSG_HR 006 0902
Serial number: KU0-KU027.04.1016921
Coding: 48BC32
Address 10: Park/Steer Assist (J446) Labels:| 6R0-919-475.clb
Part No SW: 6R0 919 475 HW: 6R0 919 475
Component: PARKHILFE 4K H07 0008
Revision: -------- Serial number: 71391011635726
Coding: 100001
ASAM Dataset: EV_VW250ParkiAssis2 S01006
ROD: EV_VW250ParkiAssis2.rod
VCID: 7BFF0526F233729C4D-802E
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 6R0 959 655 C HW: 6R0 959 655 C
Component: VW10Airbag005 H09 0018
Revision: -------- Serial number: 003DW00F8XFX
Coding: 003035
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4281B8C2D559C3544E-8016
Crash sensor for side airbag: driver side:
Serial number: 3572SRB40000B7D46A8H
Crash sensor for side airbag: front passenger side:
Serial number: 3582SRB40000B7D51A39
Crash sensor for side airbag: rear: driver side:
Serial number: 3516GRB4033DKJMR4SA7
Crash sensor for side airbag: rear: passenger side:
Serial number: 3526GRB4023EADHUPBB
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 6R0 920 861 D HW: 6R0 920 861 D
Component: KOMBI H13 0027
Serial number: 00000002323390
Coding: 140A00
ASAM Dataset: EV_DashBoardUDSJCIPQ25 A01004
ROD: EV_DashBoardUDSJCIPQ25_A01_VW25.rod
VCID: 3669D41289916FF4F2-8062
1 Fault Found:
10485825 - Internal Control Module Memory Check Sum Error
B2000 41 [137] - General checksum failure
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Address 19: CAN Gateway Labels:. 6R0-907-530-V1.clb
Part No SW: 6R0 907 530 B HW: 1K0 907 951
Component: J533 Gateway H28 0020
Revision: H28 Serial number: 160410F2001572
Coding: 7D231D00080000000002
VCID: 3261E802ADF973D4DE-8066
Address 25: Immobilizer (J285) Labels:. 5K0-920-xxx-25.clb
Component: IMMO H13 X005
Serial number:
ASAM Dataset: EV_ImmobUDSJCIPQ25 A01001
ROD: EV_ImmobUDSJCIPQ25.rod
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
Component: SG EXT.PLAYER H13 0090
Revision: A1001003 Serial number: 7668025000
Coding: 010000
VCID: 2649045251311F7442-8072
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11230
Shop #: WSC 00788
VCID: 2F67E176EACB5E3CB1-807A
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 3C8 035 195 HW: 3C8 035 195
Component: RCD510 H12 5024
Revision: -----08S Serial number: VWZ4Z3K1101833
Coding: 0500040104
Shop #: WSC 01357 011 00200
VCID: 65CB435E6CB7D46C8B-8030
2 Faults Found:
00876 - Treble Speaker Rear Left (R14)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 115
Mileage: 212173 km
Time Indication: 0
Date: 2012.07.28
Time: 15:34:46
00877 - Treble Speaker Rear Right (R16)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 115
Mileage: 212173 km
Time Indication: 0
Date: 2012.07.28
Time: 15:34:46
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 6R0 907 534 HW: 1K0 907 951
Component: Batt.regelung H28 0020
Coding: 030B1A5A
VCID: 74ED2E1AD76D3DE40C-8020
Component: J367-BDM H07 0125
Serial number: 00000000002799099872
End-------------------------(Elapsed Time: 03:01)--------------------------
